ETRO_SSN583
Level 9
Level 9
250 likes received 100 sign-ins 5 likes given
Attached project hangs on Update Components.
Creator 4.3, I think problem is emFile component.
Regards, Dana.
DheerajK_81
Hello Dana,
I tried to reproduce your issue on both PSoC Creator 4.4 and 4.3. It seems to work fine for me.
Can you please check if there is some end-point protection software or firewall that might be blocking PSoC Creator from accessing artifacts?
Please check this thread to understand how to enable access through a firewall: https://community.cypress.com/t5/PSoC-Creator-Designer-Software/PSOC-Creator-4-4-network-drive-not-s...
Hope this helps 🙂
Dheeraj
DheerajK_81
Hello Dana,
Hope this helps 🙂
Dheeraj
ETRO_SSN583
Level 9
Level 9
That fixed it, thanks Dheeraj.
Regards, Dana.
