In PSoC Creator 4.1 update 1, using PSoC 4 BLE, I'm getting errors in BLE_1_StackGattServer.h as indicated by the red circle with an X in it. The error is "Unknown Type Name 'CYBLE_API_RESULT_T' and occurs in lines 242, 282, 320, 380 and 450.
The same error shows up in BLE_1_StackGattClient.h in about 24 lines.
However, the Notice List shows no errors.
I'd be grateful is someone could tell me what's going on here.
Dennis
BLE
I have seen some similar error designations when looking at the files, but building the project works fine without causing issues, so I chalked it up to a quirk in the compiler/IDE that was more cosmetic than anything real...
Unless it is an issue, I would ignore it for now
Thanks for your response. I'll ignore the error.
Dennis
