I am facing a weird problem. I am able to program my CYBLE-102011 eval board using MiniProg3 in PSoC Creator studio. However, I am unable to program using PSoC Programmer.
I uploaded my PSoC programmer screenshots in the attachments. The settings are same as the Port Settings in PSoC Creator. I am exiting creator studio before I open PSoC program to avoid acquire conflicts.
1.PNG shows the PSoC programmer when I connect my MiniProg3 to the PC with EVAL board attached and after I click 'Progrram'
2.PNG shows up after a while with error messages.
The busy LED on the MiniProg3 never lights on even though the PSoC creator shows BUSY.
What am I missing?
Dheeraj
BLE
Hi Dheeraj,
Please reduce the clock speed in the programmer setting and try.
Anjana
Have you tried the items listed in red text in the results field?
Generally, I run into this when there is a loose connection somewhere, for me it is usually between the programmer and the PSoC.
Yes I did. As I said, I was able to program using PSoC creator. So it's not a connection issue.
Hi Dheeraj,
Anjana
This is it. It worked for speeds <=12 MHz. Thanks.
