if(uartTxDataLength >= (mtuSize - 3))
Why do we control .What is the purpose here? I did not see any information about it.
Uart_to_ble.app
if((0 != uartTxDataLength) && (NOTIFICATON_ENABLED == txDataClientConfigDesc))
uartIdleCount = UART_IDLE_TIMEOUT;
uartTxDataLength = mtuSize - 3;
else
if(--uartIdleCount == 0)
/*uartTxDataLength remains unchanged */;
else
uartTxDataLength = 0;
BLE
Basically the implementation is to send Data from UART RX over the BLE only when the UART RX receives considerable data (greater thanb MTU-3). It breaks such large data into packets of MTU-3 and sends it as individual notifications.
If the UART RX data is short (less than MTU-3), the code will wait UART_IDLE_TIMEOUT (1000 runs) for more data to arrive. Even after 1000 runs, if the UART RX does not exceed MTU-3, it will just go ahead and send whatever be the short packet it has. Till the 1000 runs is reached, it will keep looking for more data. In every run if more data has not arrived, it will just set uartTxDataLength as 0, so that no data is sent.
If you do not want a timeout kind of implementation, please set UART_IDLE_TIMEOUT as (1) in app_uart.h
- Madhu Sudhan
