Uart Rx interrupt ISR stopped after receive data at the first time. Attach code, please check and tell me what's the problem.
thanks a lot!
- psoc 4000s
- uart
I would re-write GetRecv() like below
uint32_t GetRecv()
uint8_t ch; /* changed to uint8_t */
uint32_t size = 0;
uint32_t real_size = 0;
uint8_t tmpBuffer[256];
while(UART_SpiUartGetRxBufferSize()) {
tmpBuffer[real_size++] = UART_UartGetChar() ;
if (real_size >= sizeof(tmpBuffer)) {
break ;
if (real_size > 0) {
size = WriteRingBuffer(tmpBuffer, real_size, &s_RingBuffer);
return size ;
If it does not work, I'm sorry (in advance).
moto
Check UART P4 examples in this thread and link inside
uint32_t GetRecv()
uint32_t size = 0;
break ;
return size ;
moto
Thank you very much for your guidance. I tried it and the result looks good. Thanks again!
I check the code you post, there is little difference that add a condition before call UART_UartGetChar() , Is it because the function is called too often that the interrupt is unresponsive?
UART_UartGetChar() returns 0 when no more char is available or an error arose.
But I feel accessing an empty buffer or when an error arose is not a good idea,
so I check the number of data available before accessing the buffer.
moto
