Hello All,
I am developing software for the Trackpad.
For this i have referred following two examples.
CE195394_HID_Mouse - In this example 3 Bytes mouse data is sent over USB. Byte1-Button, Byte2- X data, Byte3- Y data
CE216892 USB-HID Trackpad - In this example algorithm is developed to use trackpad and five bytes data is sent over USB.
Byte1- Button Data, Byte2- X data, Byte3 - Y data, Byte4- 0 (Scroll), Byte5 - XY negative sign data.
In this example CE195394_HID_Mouse USB HID Descriptor is available for 3bytes.
I am using algorithm from this example CE216892 USB-HID Trackpad and descriptor from CE195394_HID_Mouse this example.
I have to modify the descriptor for five Bytes. Here What item value should I select for XYdirection data.
XYdirection is uint8 variable and values are either 1, 2 & 3.
if someone has worked on this USB HID Touchpad/Trackpad example please help.
Thank you.
PSoC 4 MCU
Hi @JaMa_1051561 ,
I see you have already explained the same issue in another community thread of yours - USB HID Descriptor for Trackpad - Cypress Developer Community . I suggest you to follow up the already going on discussion in that thread itself. Also, please let us know your related queries there. I will go ahead and close this discussion here then.
Thanks and Regards,
Aashita
Hi @JaMa_1051561 ,
Thanks and Regards,
Aashita
