Hello
I have started using Cy8cKit-042 BLE module. And I came across
This link: <https://github.com/cypresssemiconductorco/PSoC-4-BLE/tree/master/100_Projects_in_100_Days>
Project 20 UART_BLE
I tried connecting with PSoc 4 BLE device (CY8C4247LQI-BL483) module and it works perfectly but when I tried to use EZ-BLE PSoc Module (CYBLE-224110-00) module, so that I can test connection for long range, but it is not working. I tried changing chip and pin configuration acc. to schematic but did not work.
So any suggestion and help how can I proceed?
Thank you
Aashram
Hello Aashram,
Can you please tell us what is the issue. Is it compilation issues or connection issue
Hima
Hello Aashram,
Hima
Hello Hima,
As in picture I am trying to connect two PSoc 4 BLE device (CY8C4247LQI-BL483) with EZ-BLE PSoc Module (CYBLE-224110-00) for 50 meter range. My 'Central' works perfect but 'Pheripheral' is not working. But when I use another module instead of EZ-BLE PSoc Module (CYBLE-224110-00) as 'Pheripheral' then everything works perfect.
Am I missing something??
With my server I can not attach any pictures
Sorry
After looking on community, I found where I went wrong:
http://www.cypress.com/forum/psoc-4-ble/connecting-two-cyble-224110-eval-between-them
This linked helped.
I thought by using long distance EZ-BLE PSoc Module (CYBLE-224110-00) module the amplifier by defaults is on.
But now all works
