PSoC™ 4 Forum Discussions
Hi All,
working with the CYBLE222014-01 and trying to get DFU over UART using an external micro controller. I've been trying to implement the HOST side code from AN68272 into my own micro controller.
My current process is to send the EZ-serial command to reboot the module into UART DFU mode, which I believe it occurring successfully. After that I utilize the BootloadStringImage function. I generate my string using the included string generator in AN68272.
I believe the process starts out okay, but I seem to be running into issues now where in the main loop that's supposed to extract each row of the string image, I come across error 0x4003, which has to do with the size of the data? The comment in the code isn't very clear what this error means though. Any ideas?
GeonaP_26
250 solutions authored 100 solutions authored 50 solutions authored
Bootloader_ERR_DATA is generated when the data is not of the proper form. Please share the command log. Which command is triggering this error?
Hi geon,
the error seems to occur when the host tries to send the first line of the .cyacd file. I am trying to update to FW 1.1.1 on my cyble222014-01.
The first line of the .cyacd is as follows:
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
In CyBtldr_ProgramRow() function, the problem seems to come up when it gets to the last section of the row data.
GeonaP_26
Can you share the log of command and response packets over UART? This will help us to confirm whether the packet is in proper form.
Does the host code have some sort of automatic logging functionality? Or will I need to implement this myself?
I've added some debug code to my micro controller. Currently this is what I'm seeing when I start the bootloadstringimage function. I've also attached the string converted .cyacd file I'm utilizing.
Byte written: 0x1
Byte written: 0x38
Byte written: 0x0
Byte written: 0x0
Byte written: 0xc7
Byte written: 0xff
Byte written: 0x17
Byte Received: 0x1
Byte Received: 0x4
Byte Received: 0x0
Byte Received: 0x0
Byte Received: 0xfb
Byte Received: 0xff
Byte Received: 0x17
Byte Received: 0x1
Byte Received: 0x4
Byte Received: 0x0
Byte Received: 0x0
Byte Received: 0xfb
Byte Received: 0xff
Byte Received: 0x17
Byte Received: 0x1
Byte written: 0x1
Byte written: 0x3b
Byte written: 0x1
Byte written: 0x0
Byte written: 0x0
Byte written: 0xc3
Byte written: 0xff
Byte written: 0x17
Everything seems to get stuck at this point...
GeonaP_26
You can use anlyser to log communication packets. 0x3B is Exit Bootloader command which is not acknowledged. Please share the bootloader project to recreate the issue at our end. Meanwhile, are you facing any issues with normal UART application at same baud rate?
I will share code shortly.
As far as UART application... I'm using baud of 115200 currently. This speed works fine with EZ-serial application. Should it be different when in DFU mode? The ez-serial application note says to use 115200 when in DFU mode.
GeonaP_26
You can use a baudrate of 115200. Meanwhile, please confirm whether you face this issue at other baudrates.
I will try out different baud rates and return with the results.
Out of curiosity, does it matter if I update the stack as well as the app? The reason I ask this is because I tried to upgrade the app of one module OTA, and it seems to be stuck in some unknown state now. However when I tried to update OTA the stack and the app, it seemed to work properly?
Do I need to update the stack first before the app perhaps? And if so, how would I go about doing that if I'm doing the update via UART?
Again for reference, I'm trying to update modules with app 0x1000225.
GeonaP_26
Please confirm whether you are using, Upgradable Stack OTA configuration. If yes, Application Upgrade can be done in single step. There is no need to update stack project.
Whereas for stack application firmware update, user needs to update both stack and application projects. Please refer to section: 4.3 Upgradable Stack OTA Bootloader of AN97060
Could you explain more details regarding your system? What is the dataflow for new firmware upgrade?
Hi geon,
I'm not entirely sure what you mean by configuration? To reiterate what I'm trying to do. Using an external micro, I'd like to update the app version of my CYBLE222014-01 via UART from . I've been trying to use the example host code provided in AN68272, but I am running into the aforementioned issues.
As an experiment, I tried to update the module OTA. Initially I just tried to update the app with this method, but it has left my one module in an unknown state. I tried the OTA on another module, this time also updating the stack, and it seems to have worked.
Therefore I'm wondering if for the UART update, I need to upgrade the stack as well as the app, and if this is the case, how do I do both via UART?
GeonaP_26
Are you using dual bootloadable architecture? Please share the workspace to understand the bootloader and bootloadable project configurations.
Hi Geon,
I'm still trying to figure out how best to share my workspace with you. I'm not currently at liberty to share my whole project.. Is there a way to do it privately?
Otherwise, I've essentially just integrated the boot loader host code from AN6872, only modifying the UART section so that it works with the UART of my ST micro controller.
Two questions:
1) Can I update the stack the same way I would update the app?
2) When comparing the string image in the original AN6872 example with my string image that I generated using the string image generator, it seems that my string image has a row length more similar to PSoC3 image, than PSoC4... Could this be a problem?
