Hello everyone,
I want to design touchpad coding and Topdesign. I am the new one on this area. I want to design a thing which has following specifications:
-define a button on touchpad and when I touch this area led should on.
-define a slider on touchpad and when I scroll my finger specified led brightness should increase step by step.
Is there anyone who can help me?
Thank you in advance!
Marcus
PSoC 4 MCU
- touchpad
Hi Marcus,
Please refer to https://www.cypress.com/documentation/development-kitsboards/cy8ckit-149-psoc-4100s-plus-prototyping... getting started with your design, this kit uses CY8C4147AZI-S475 which is an industrial version of the chip CY8C4147AZS-S475.
And you may won't want to miss https://www.cypress.com/documentation/application-notes/an85951-psoc-4-and-psoc-6-mcu-capsense-desig...
If you have PSoC Creator software installed on your machine, you can quickly find some examples from File > Code Example... as below:
I am using CY8C4147AZS-S475 MCU.
Hi Marcus,
