There was an error running port acquire: Can not acquire SWD device!
Leo_liu1
Level 4
Level 4
50 replies posted 25 replies posted 10 replies posted
     I can  program  success only in the first time. after that,it always point "There was an error running port acquire: Can not acquire SWD device!" how can i program it again,thanks~
RyanZhao
250 sign-ins First question asked 750 replies posted
Hi Leo,
Seems that the KitProg is in CMSIS-DAP mode. Kindly refer this thread.
Kitprog stops working after firmware update (CY8CKIT-059)
Ryan
RyanZhao
Hi Leo,
Ryan
Hi,Rzzh,
     Thank you very much !
     You solved my problem perfectly.
SrikanthD_56
25 sign-ins First question asked First comment on blog
Which kit are you using? By looking at your project, I guess you are using CY8CKIT-042-BLE.
Please make sure that the jumpers on the are at their default position before programming, by referring to the kit guide.
Currently I see that you are using the KitProg in CMSIS-DAP/Mass Storage mode. Try changing the KitProg to default programming mode and then try programming the device, see if that helps. Refer to section 4.1 Enter or Exit the Mass Storage Programmer Mode of KitProg User Guide for steps to change the KitProg mode.
Hi,Srds,
          The reason for this mistake is that I accidentally pressed the reset button for more than 5 seconds.
Thank you for your reply.
