I am trying a Driven-Shield with a handmade sensor with CSD.
The touch to the adjacent sensor affects the Signal value, and the Baseline gradually follows.
Since the Noise threshold is not exceeded, the Baseline will gradually follow.
1. Is increasing the distance between the sensors the only solution to solve this problem?
2. Can it be solved by enabling some filter?
Yocchi
PSoC 4 MCU
Hello Yocchi san,
Yes, here increasing the space between the sensors is the only way. You can also try providing the shield between the two sensors (if this is not already done) so that it provides isolation between the sensors.
I also see that you are getting very large SNR, so you can also try to reduce the resolution of the sensors so that you are closer to 5:1 SNR so that the increase in the adjacent sensor's signal is smaller.
Hari
Hello Yocchi san,
Hari
