Is there any way to configure CYBLE-012011-00 ADC for monitoring Supply Voltage (without using external components)?
More is there a way to change ADC Reference Source from Internal VREF to VCC?
Alfonso
BLE
Hello Alfonso,
The SAR intenral ADC can take voltage reference as internal Vref, External Vref,VDDA and VDDA/2. The reference option should be from any of these. Regarding SARADC monitoring the supply voltage, there is an example code already available to monitor the battery level( or supply voltage) without external components. The project uses only one external connection to the ADC input. In PSoC Creator(File-> Example Code) find BLE_Battery_Level example.
Vasanth
Hello Alfonso,
Vasanth
Hi Vasanth,
Thanks for the suggestion.
Alfonso
