PSoC™ 4 Forum Discussions
NeDh_4602711
50 replies posted 25 replies posted 25 sign-ins
Could you please help me to choose the right module? I want to scan for BLE (which will give me data of MAC, LocalName,RSSI etc of nearby device) (scanner) as well as simultaneously I want to transmit the BLE signal (Transmitter) and It should be small in size.
Thanks in advance.
Neeraj Dhekale
VenkataD_41
Hi Neeraj,
You can get all the information you asked from the advertisement packet. You just have to scan the devices and check the event SCAN_PROGRESS_RESULT.
Please refer the following application note for complete information regarding all available BLE modules. You can select the modules based on the type of antenna and range. You can select any module for your application.
https://www.cypress.com/documentation/application-notes/an96841-getting-started-ez-ble-creator-modul...
Hope this helps !
Ganesh
VenkataD_41
Hi Neeraj,
Hope this helps !
Ganesh
Thank you Ganesh,
Neeraj
Hi Ganesh,
Could you please suggest the CYBT-343026-01 module will be suitable for me for above requirement? Click here
Thanks and regards,
Neeraj
