YoIs_1298666
250 sign-ins 100 replies posted 100 sign-ins
I have two quesitons about PSoC4100S ADC SAR Seq.
1.About the converted resolution in case of each Single ended negative input for PSoC4100S.
 Is my understanding correct?
   [a. In case of "Vref select: VDDA/2 bypassed" and "Single ended negative input: Vref" ]
     The conversion resolution is 12bit.
   [b. In case of "Vref select: VDDA/2 bypassed" and "Single ended negative input: Vss" ]
    The conversion resolution is 11bit.
   [c. In case of "Vref select: VDDA" and "Single ended negative input: Vss" ]
2.In case of [b in 1]., even if the analog input voltage exceeds Vref, is it not broken if it is below VDDA?
 Is the conversion result of the analog input voltage exceeding Vref Vref value?
Yocchi
Ishii-san,
The analysis of [a, b, c] in your response#2 are correct.
And Yes. In case of [b in 1]., even if the analog input voltage exceeds Vref, is it not broken if it is below VDDA.
Ryan
odissey1
Level 9
Level 9
Yocchi,
From practical point of view it is probably irrelevant, as ADC last bit usually contains the noise.
/odissey1
YoIs_1298666
ello,
I have a misunderstanding for the following document.
It seems that the correct is understanding below?
From the datasheet, it seems that we can input up to VDDA.
Yocchi
Ishii-san,
Ryan
Hello Ryan-san,
Thank you very much.
Yocchi
