Hello, after a few tries with example Codes, I wanted try a "full custom" program.
I'm using Evalkit PSoC4000S with 4045 Controller.
Now I have added and configured incl. Pin's a Capsense and a EZI2C component.
First I only want test/detect one Button (CSD) with the Launch Tuner.
Now I think I have problem with the main.c implementation. Respectively I have difficult to understand all the function with correct order, position and which one has to be to use. Please find below my first Code. After starting the Tuner I cannot detect any Signal:
#include "project.h"
CyGlobalIntEnable; /* Enable global interrupts. */
/* Place your initialization/startup code here (e.g. MyInst_Start()) */
/* Start EZI2C block */
EZI2C_Start();
/* Set up communication data buffer to CapSense data structure to
* expose to I2C master at primary slave address request
EZI2C_EzI2CSetBuffer1(sizeof(CapSense_dsRam), sizeof(CapSense_dsRam),\
(uint8 *)&CapSense_dsRam);
/* Start CapSense block - Initializes CapSense data structure and
* performs first scan of all widgets/sensors to set up sensors
* baselines
CapSense_Start();
CapSense_ScanAllWidgets();
CapSense_RunTuner();
for(;;)
if((CapSense_NOT_BUSY == CapSense_IsBusy()))
#if (TUNER_UPDATE_ENABLE)
if(CapSense_STATUS_RESTART_DONE == CapSense_RunTuner())
/* Set up sensor */
CapSense_CSDSetupWidgetExt(CapSense_BUTTON0_WDGT_ID, CapSense_BUTTON0_SNS0_ID)
#endif
CapSense_CSDSetupWidgetExt(CapSense_BUTTON0_WDGT_ID, CapSense_BUTTON0_SNS0_ID);
CapSense_CSDScanExt();
/* [] END OF FILE */
thank you very much
Hi Pierre,
In the for loop, the required code should be:
Scan sensors;
Wait for scan completed;
Process scan data;
It lacks 'processing scan data' in your code.
Here is a simply example:
int main()
CyGlobalIntEnable;
/* Initialize I2C component for CapSense tuner */
EZI2C_Start();
/* Initialize the CapSense CSD block */
CapSense_Start();
while(CapSense_IsBusy()){}
CapSense_InitializeAllBaselines();
/* The main for loop */
for(;;)
/* Scan */
/* Wait until scan complete */
/* Process */
CapSense_ProcessAllWidgets();
/* Run Tuner */
To run tuner smoothly, remember to set sub-address size(bits) of EzI2C as 16.
You can also refer code example in the component datasheet.
Ryan
