PSoC™ 4
I'm attempting to set the current time of my RTC by sending a Unix timestamp from a smartphone to the device. I am successfully able to get the timestamp from my smartphone to the ble device.
If I try to just hardcode something to test like this:
uint64_t out = 1475591308;
RTC_SetUnixTime(out);
My RTC clock goes to 1/11/2372 ??  Am I not implementing this right? The method signature in the RTC.h is:
RTC_SetUnixTime(uint64 unixTime);
And the docs say:
Sets the time in the Unix/Epoch time format - the number of seconds elapsed from January 1, 1970 UTC 00:00 hrs.
Update: I've changed nothing and now when setting the unix time it freezes....story of my life.
I'm trying to call RTC_SetUnixTime in my BleCallBack method if that helps at all.
So I was able to fix this by adding in a couple of variables and updating the RTC from the main method instead of my BleCallBack method. So in my main now I have:
if (!clockIsUpToDate) {
      RTC_SetUnixTime(newClockValue);
      clockIsUpToDate = 1;
I think my issue with this is not fully understanding the c run loop.
