I want to send String data using uart and receive string data using uart on cy8c4245axi-483. I want sample code for doing this.
Please Help,
PSoC 4 MCU
- uart
Sanjay,
attached is example of fixed function SCB UART Rx for PSoC4200M (KIT-044M). In this demo, simple text commands (e.g. "R255", "G127", "B10") from UART terminal (like TeraTerm or Putty) are used to control RGB LED intensity. If command is not recognized, MCU replies with error message.
Do not forget to use CR, LF (or both) when sending control commands.
/odissey1
Hi @sanjay_ailani,
Can you please check this code example and let us know if it helps? - CE224431 - PSoC 4 UART printf
Rakshith M B
Sanjay,
/odissey1
KIT-042 Annotation Component will help you with pins assignment on CY8CKIT-042, and using USB-UART bridge built-in into onboard PSoC5
KIT-042 annotation component for CY8CKIT-042 Pioneer Kit
