niprc_3742601
Level 4
Level 4
Is it possible to have a multiple of pin-out configurations under a single PSoC Creator project?
I want to be able to build same project, but with different pin assignment configurations.  Changing pin assignments manually every time is very tedious and having a multiple copies of the same project with different pin assignments sounds like big redundancy.  So I wonder if it is possible to save different ping assignment configuration in separate files and load the desired file before a particular build.  Does PSoC Creator have anything like this?
Thanks!
Nikolay
odissey1
Level 9
Level 9
Nikolay,
It is possible to make one set of schematic (including pins) on one page, and another schematic with same component names on another page. Enable only one schematic page  at a time to avoid error messages.
/odissey1
odissey1
Level 9
Level 9
Nikolay,
/odissey1
Thank you very much!
