Is it possible to have a multiple of pin-out configurations under a single PSoC Creator project?
I want to be able to build same project, but with different pin assignment configurations. Changing pin assignments manually every time is very tedious and having a multiple copies of the same project with different pin assignments sounds like big redundancy. So I wonder if it is possible to save different ping assignment configuration in separate files and load the desired file before a particular build. Does PSoC Creator have anything like this?
Thanks!
Nikolay
Nikolay,
It is possible to make one set of schematic (including pins) on one page, and another schematic with same component names on another page. Enable only one schematic page at a time to avoid error messages.
/odissey1
Nikolay,
/odissey1
Thank you very much!
