Return sequence after all clocks are stopped?
NXTY_Tatebayasi
Level 6
Level 6
Distributor - NEXTY (Japan)
100 replies posted 100 likes received 50 likes received
Hi, Community
I am considering designing an external crystal (ECO) with PSoC 4100 S Max.
If there is a system reset or an event that causes all clocks to stop (e.g. Stop ), what is the sequence of events that causes the ECO to oscillate next?
Does the ECO automatically resume oscillation when the system returns from those events?
Chihiro Tatebayashi
LinglingG_46
500 solutions authored 1000 replies posted 10 questions asked
If you call the API "Cy_SysPm_CpuEnterDeepSleep();", then the HFCLK will be disabled.
But after wakeup it will resume.
More please check the linker file:
 https://www.infineon.com/dgdl/Infineon-PSoC_4100S_Max_PSoC4_Architecture_Technical_Reference_Manual_...
LinglingG_46
NXTY_Tatebayasi
Level 6
Level 6
Hi, @LinglingG_46  -san
Thank you for telling us about it.
I found out that in case of stopping the clock by calling deep sleep or stop, it is necessary to call an interrupt such as wake up to release those states.
So am I correct in assuming that all stopped clocks can automatically start oscillating (without the user having to call a separate API) once the system satisfies the requirements to return?
Chihiro Tatebayashi
Yes, after the system resume from deepsleep state, the clock will automatically start without calling any APIs. Actually, the operation of calling API relies on the clock.
NXTY_Tatebayasi
Level 6
Level 6
Thank you very much.
Just solved my problem!
Chihiro Tatebayashi
