12:52 AM
Jan 17, 2014
12:52 AM
Hi everybody, We finally started moving our designs from another CPU over to PSOC4. But with the other CPU dev tools I was able to exclude flash regions when reprogamming, to retain settings written to flash. How do I do that with Creator? We have 5 identical boards in our machine, all driving one or two motors and connected together via a bus(LIN signal levels/line drivers, but custom protocol). The problem is that each board needs to be set up with custom PID settings etc and I can't keep a custom code base for each board. So I write the custom settings to the emEPROM, but the setings are lost at every reprogram. How can I prevent that? Thank you, Errol
