PSoC™ 4 Forum Discussions
YuMa_1534086
Level 6
Level 6
10 likes received 100 solutions authored 50 solutions authored
Hello
Q1)
Could you please let us know solution in case diff count with finger-touch saturated because sensitivity is too high.
I think that there are the following methods.
Please check whether they are correct or not.
And could you please let us know if there are other solutions.
[IC tuning]
- Decreased calibration target        (increased IDAC value)
- Disabled compensation IDAC      (increased CP => increased IDAC)
- Disabled shield                             (increased CP => increased IDAC)
[Hardware]
- Increased CP                                (increased IDAC value)
- Changed overlay                          (decreased sensitivity)
Q2)
Could you please let us know solution in case IDAC saturated
[IC tuning]
- Increased calibration target          (decreased IDAC value)
- Enabled compensation IDAC       (Increased IDAC drive ability)
- Enabled shield                              (decreased CP => decreased IDAC)
- “Inactive sensor connection” changes from GND to shield.  (decreased CP => decreased IDAC)
[Hardware]
- Decreased CP                              (decreased IDAC value)
- mesh pattern changes from GND to shield (decreased CP => decreased IDAC)
Best Regards.
Matsubara
RyanZhao
750 replies posted 100 sign-ins 100 likes received
Hello Matsubara-san,
Comments below are FYI.
Q1)
Solution in case diff count with finger-touch saturated because sensitivity is too high.
[IC tuning]
- Decreased calibration target        (increased IDAC value)                           - Correct
- Disabled compensation IDAC      (increased CP => increased IDAC)         - Correct, but CP not increased. Software changing will not change CP.  See Figure 5-12 in AN85951(https://www.cypress.com/documentation/application-notes/an85951-psoc-4-and-psoc-6-mcu-capsense-desig... )
- Disabled shield                             (increased CP => increased IDAC)         - Correct, at the same time, it is better to connect mesh pattern with GND. If leave them float, CP will not be increased effectively.
[Hardware]
- Increased CP                                (increased IDAC value)                            - Correct
- Changed overlay                          (decreased sensitivity)                              - Correct
Increasing CP or decreassing sensitivity(CF) is the best choice to solve diffcount saturated.
Q2)
Solution in case IDAC saturated
[IC tuning]
- Increased calibration target          (decreased IDAC value)        - Correct
- Enabled compensation IDAC       (Increased IDAC drive ability)                                                           - Correct
- Enabled shield                              (decreased CP => decreased IDAC)                                                - Correct
- “Inactive sensor connection” changes from GND to shield.  (decreased CP => decreased IDAC)       - Correct
[Hardware]
- Decreased CP                              (decreased IDAC value)        - Correct
- mesh pattern changes from GND to shield (decreased CP => decreased IDAC)                                  - Correct
Ryan
RyanZhao
Q1)
[IC tuning]
[Hardware]
Q2)
[IC tuning]
[Hardware]
Ryan
Ryan-san.
Thank you for your support.
I understand.
Best Regards.
Matsubara
