YuMa_1534086
Level 7
Level 7
Distributor - Macnica (Japan)
500 replies posted 250 sign-ins 10 likes received
Hi Infineon.
Could you please let us know how to use external clock instead of internal clock on PSoC 4000S?
Can user use external clock by following 2 steps?
Are there any other steps required to use external clock, such as adding code other than below 2 steps?
If user implement below 2 steps, will the clock source be switched from IMO to external clock?
If user implement below 2 steps, will IMO stop and switch to PSoC operation using external clock?
Step 1:
Check EXTCLK to enable external clock.
Change HFCLK source from IMO to EXTCLK in the pull-down menu.
Step2:
Connect an external clock to P0_6.
Best Regards.
YuMa
Ekta
750 replies posted First like given 250 solutions authored
Hi @YuMa_1534086
Yes, there are no additional steps required.
Are you facing any issues when setting Extclk as the source of HFCLK?
Best Regards
Ekta
YuMa_1534086
Level 7
Level 7
Ekta-san.
Thank you for your support.
I understand.
This does not mean that there is any particular problem.
I confirmed setting method just to make sure.
Best Regards.
YuMa
