Equip yourself to optimize PSoc4 MCUs for Evs at the EV Webinar. Click here to register.
PSoC™ 4 Forum Discussions
YuMa_1534086
Level 6
Level 6
100 solutions authored 50 solutions authored 25 solutions authored
Hello Cypress
Q1)
Could you please let us know current consumption of inductive sensor(PSoC4700S)?
Is there general current consumption data at some modes(active, low power, etc)?
Is it possible to work below 0.1W(inductive sensor channel is 2ch)?
There are no detailed operating conditions other than number of channel, as customer only want to know approximate values.
Could you please provide general data of inductive sensor’s current consumption that cypress has?
Q2)
Is there sample project of inductive sensor at low power?
Best Regards.
Yutaka Matsubara
Apology again for late response...
I confirmed that there is no (measurement) power modes current for MagSense with a CY148-KIT, now.
And also, no PSoC creator project example for MagSense is available...
We can see the only DC current and power modes describe in PSoC4700S datasheet.
YuMa_1534086
Level 6
Level 6
Hello Cypress.
About Q1).
There is power consumption data example at inductive sensing component datasheet.
Do you have any reference data other than below?
Best Regards.
Yutaka Matsubara
Hello Cypress.
Can you update this discuss?
Best Regards.
Yutaka Matsubara
Apology for late response for this thread.
However, we still need some time to check internally.
Once we get any information, will update this thread.
Thank you for your reply.
Will sample code of MagSense at low power mode be added in the future, like capsense at low power mode?
I think that current consumption at low power mode will be important factor, if user uses MagSense.
Best Regards.
Yutaka Matsubara
Thank you very much for your comment for this.
Now, there is a concrete plan for Code Example of MagSense at low power mode.
However, it can be added in future road map.
Thank you for you reply.
I understand it.
Best Regards.
Yutaka Matsubara
