Regarding CSX calibration target.
YuMa_1534086
Level 7
Level 7
Distributor - Macnica (Japan)
500 replies posted 250 sign-ins 10 likes received
Hello Cypress.
Q1)
CSX default calibration target is 40%.
Why did Cypress decide 40% as recommended value?
CSD calibration target is 85% or 75%.
CSX calibration target setting is lower compared to CSD target.
Could you please let us know reason and background why CSX calibration target became 40%?
Why is calibration target of CSD and CSX not same value?
Q2)
Could you please let us know advantage and disadvantage if CSX calibration target is changed to higher value or lower value than 40%?
Best Regards.
Yutaka Matsubara
RyanZhao
250 sign-ins First question asked 750 replies posted
Matsubara-san,
Q1). We inverts raw counts in CSX operation to get similar finger touch reaction to CSD operation. I.e. when you touch a button, raw count increses (CSD). But in CSX operation,  raw count decreses. Therefore we invert raw count in CSX operation. So the actual calibration level of CSX is (1-40%) = 60%.   Why we select 60%(40% after inverted, with risk of flat spots) instead of 85%(15 after inverted)? 85% will be too high for many applications, we adjust it to in CSX firmware. Suggest using SSC clock in most applications, if flat spots occurred with direct clock mode, we can set it back to 85%(15% after inverted).
Q2). Advantage and disadvantage is similar with CSD. Higher calibration level (lower after inverted) will give better gain of rawcount-Cf.
Disadvantage could be risk of signal saturation. Lower calibration level (higher after inverted) will have no risk of  signal saturation but flat spots.
Ryan
RyanZhao
Matsubara-san,
Ryan
YuMa_1534086
Level 7
Level 7
Ryan-san.
Thank you for your response.
Is this the same for CSD?
If yes, is there possibility that CSD default calibration target changes in the future?
Best Regards.
Yutaka Matsubara
Matsubara-san,
Sorry sincerely for the late reply.
Yes. It is same for CSD. the default calibration level may be changed in the future, but we don't have concrete time schedule yet...
Ryan
YuMa_1534086
Level 7
Level 7
Ryan-san.
Thank you for your reply.
I understand.
Best Regards.
Yutaka Matsubara
