Hello Cypress.
Q1)
Why does not CSX have PRS setting?
Is there any reason why CSX can not drive at PRS?
Q2)
Does CSX have flat spots issue same as CSD?
Q3)
If Q2 is yes, where is the point where flat spots issue occurs?
Are they the same as CSD? So 25%, 50% and 75% of CSX max RawCount?
And how should CSX avoid flat spots issue?
CSX does not have PRS.
Best Regards.
Yutaka Matsubara
Matsubara-san,
A1) PRS may have large noise and low SNR for CSX
Q2) Yes. With larger CintA/B than our recommendation, the flat spots will be more obvious. With the recommended CintA/B, the flat spot may not be observed obviously.
Q3) Yes. 25%, 50% and 75% of CSX max RawCount.
SSC can help to avoid Flat Spots same with PRS.
Ryan
Matsubara-san,
Ryan
Ryan-san.
Thank you for your response.
Below is design guide description about flat spots.
According this description, it seems that only way to avoid flat spots is to use PRS.
Because design guide describes only PRS.(There is no SSC)
But you said that SSC can help to avoid Flat Spots same with PRS.
In actual, is SSC also useful for avoiding flat spots same as PRS?
If yes, which of PRS and SSC is better in order to avoid flat spots?
Best Regards.
Yutaka Matsubara
Matsubara-san,
Sorry sincerely again for the late reply.
Either SSC and PRS can avoid flat spots. Flat spot will happen under direct clock mode. To resolve the problem, spreading a clock can be used. SSC is a spectrum spreading clock, can also make sense for avoiding flat spot same with PRS.
Ryan
Ryan-san.
Which of PRS and SSC is better in order to avoid flat spots?
Or is there no significant difference as solution of flat spots?
Best Regards.
Yutaka Matsubara
Matsubara-san,
There is no significant difference as solution of flat spots.
Ryan
Ryan-san.
I understand it.
Best Regards.
Yutaka Matsubara
