Recognizing Sliding Gesture
AnRa_1522781
I am using PSoC4 CapSense_2.10. I would like to carry out an action like turn an LED on when the sliding gesture is carried out on a slider or any capsense widget.
By sliding gesture I mean that all the capacitive sensing elements in the slider have to touched in a sequence or the finger has to slide through all of them to recognize the slide gesture. Is this possible with any CapSense Widget?
regards
Yuva
250 replies posted 250 sign-ins 100 solutions authored
There is no specific API to decode the gesture for this component, so you have to do your own logic. One other option is use CapSense_Gestures component available in the BLE devices which have gesture decoding capability for touchpad which you can use for slider also.
Yuva
AnRa_1522781
Could you explain how the gesture decoding would work for a slider using CapSense_Gestures? I thought it only works for touchpads.
