Hello all,
I want to be able to read the voltage difference of 2 electrodes over Bluetooth using Psoc 4 BLE. Are there any already existing codes that do this? I'd appreciate any help or tips as I am just starting.
PSoC 4 MCU
- cy8ckit-0420-ble
You can achieve this requirement in two steps.
1. Reading the voltage levels of the electrodes using ADC and find the voltage difference. You can use single-ended or differential ADC for this purpose.
2. Transfering the data over BLE to a peer device.
Please refer to the following project from Github.
You can also refer to the remaining projects from the Github space for more understanding.
https://github.com/Infineon/PSoC-4-BLE/tree/master/100_Projects_in_100_Days
Thanks and regards
Ganesh
Thanks and regards
Ganesh
Please find the attached pair of projects where one PSoC 4 BLE is used as BLE Central-Client and the other PSoC 4 BLE is used as Server-Peripheral. Different APIs are used in different projects to transfer the data between two devices (central and peripheral). I hope that these projects will give you an idea to use the right APIs for data transmission.
Thanks and regards
Ganesh
