Equip yourself to optimize PSoc4 MCUs for Evs at the EV Webinar. Click here to register.
PSoC™ 4 Forum Discussions
AdamCheng
Hi everyone,
When I press button.
I want to read Capsense finger signal value and output to another software .
Which is finger signal in capsense data structure ?
Hari
Hi @AdamCheng
You can read the CapSense raw counts or difference counts (diff counts is the signal level that you see when touched. It is 0 when not touched and raw - baseline when touched) by using the CapSense_GetParam API. This returns the values and the param ID can be found in CapSense_RegisterMap.h file.
You can also read the value directly from the data structure. It is present in the following location -
CapSense_dsRam.snsList.<wdgtid>[0u].raw[0u]
CapSense_dsRam.snsList.<wdgtid>[0u].diff
Hari
Hari
Hi @AdamCheng
Hari
AdamCheng
Dear Hari,
Thank you for the information.
