Bob_Marlowe
Level 10
Level 10
Although there is a #define DEBUG made when compiling in debug mode there is no choice to in- or exclude a component based on that.
The reason for that is: the fitter process runs before any C-Language is compiled and so does not "see" any external symbols.
BUT
You can do it the other way: In each ComponentName.h file a symbol is #defined which you may use for conditional compiling.  So you just need todisable your bootloadable (and bootloader when you use both) in the Top>>Design schematic.
Bob
