This is the complete code of my Project and below this code I have uploaded the Screen Shot.
#include "project.h"
#define ENABLED (1u)
#define DISABLED (0u)
#define NON_APPLICABLE (DISABLED)
#define UART_TX_INTR_MASK (0u)
#define SCB_1_UART_OverSampling 13u
#define UART_RX_BUFFER_SIZE (COMMON_BUFFER_SIZE)
#define UART_TX_BUFFER_SIZE (COMMON_BUFFER_SIZE)
#define UART_RX_BUFER_PTR bufferRx
#define UART_TX_BUFER_PTR bufferTx
#define UART_RX_INTR_MASK (SCB_1_INTR_RX_NOT_EMPTY)
#define COMMON_BUFFER_SIZE (16u)
uint8 bufferTx[COMMON_BUFFER_SIZE];
uint8 bufferRx[COMMON_BUFFER_SIZE + 1u];
static int k=0,j=0;
char s;
uint8 databits=0x08u;
uint8 parity=SCB_1_UART_PARITY_NONE;
SCB_1_UART_INIT_STRUCT config=
0u,3u,0x08u,2u,4u,13u,0u,0u,0u,0u,0u,0u,0u,UART_RX_BUFFER_SIZE,
UART_RX_BUFER_PTR,UART_TX_BUFFER_SIZE,UART_TX_BUFER_PTR,0u,0u,
0u,0u,1u,UART_RX_INTR_MASK,0u,0u,0u,0u,0u,0u,0u,0u
char string[10];
int32 source=0;
int i=0;
CyGlobalIntEnable;
SCB_1_UartInit(&config);
SCB_1_Start();
Clock_1_SetFractionalDividerRegister(180u,0u);
for(;;)
s=SCB_1_UartGetChar();
string=s;
if(s!='\0')
SCB_1_SpiUartWriteTxData(s);
s='\0';
ScreenShot:
Would be nice when you follow my advice... It is fewer work for me to open your project in the ide.
Bob
