Nov 27, 2019
01:33 PM
Nov 27, 2019
01:33 PM
Hello I have 470MHZ RF transmitter and Receiver I want to Use them to make two Psoc 4 Poinner kit communicate.
First Psoc 4 get the result from the gas sensor MQ4.
Second Psoc 4 should receive the data from the first psoc 4 Via RF receiver.
I have a problem on writing the code and top design in Psoc creator need help.
12:49 PM
Nov 28, 2019
12:49 PM
MoAl,
Here's a few questions for you:
- What is the communication bus to your 470MHz transmitter? SPI, I2C, other?
- What is the communication bus to your 470MHz receiver? SPI, I2C, other?
- Have you already selected the PSoC 4 kits to use? If not consider the CY8CKIT-042-BLE PSoC Kit. The BLE is designed for sensor applications. You can eliminate the need for your 470MHz narrowband radio.
Len
Len
Dec 25, 2019
06:19 PM
Dec 25, 2019
06:19 PM
