user_3159566
First like given
I'm trying to understand the Sensored BLDC Motor Control example project included in Sensored BLDC Motor Control. The PID controller looks like a PD controller to me but everything is explained as a PI controller. Is that ok?
void SpeedPID(void)
    int16 speedErr;
    static int16 speedErrPrev = 0x00;
    int16 speedErr2;
    int32 result;
    uint16 kp,ki;
    if(speedRef > MIDDLE_SPEED_CMD)         /* Low Speed, Low Coef  */
        kp = UI_Data.kp;
        ki = UI_Data.ki;
    else                                    /* High Speed, High Coef  */
        kp = UI_Data.kp << 1;
        ki = UI_Data.ki << 1;
    speedErr = speedCur - speedRef;
    /* Calculate output of intergration */
    result = (int32 )(speedErr * ki); //PROPORTIONAL???
    piOut += result;
    /* Calculate output of proportional */
    speedErr2 = (speedErr-speedErrPrev); //DERIVATIVE???
    speedErrPrev = speedErr;
    result = (int32)(speedErr2 * kp);
    piOut += result;
    if(piOut>PIOUT_MAX)
        piOut= PIOUT_MAX;
    if(piOut<PIOUT_MIN)
        piOut= PIOUT_MIN;
    dutyCycle = piOut>>16;
    PWM_Drive_WriteCompare(dutyCycle);
JobinT_31
50 solutions authored 25 solutions authored 10 solutions authored
Hello Manuel,
In PID, Integration represent the accumulation of the errors [multiplied to a constant] over time.
  1. /* Calculate output of intergration */
  2.     result = (int32 )(speedErr * ki); //PROPORTIONAL???
  3.     piOut += result;
Here you can see the piOut += result; accumulating all the errors. piOut will have the sum of all the errors.
  1. /* Calculate output of proportional */
  2.     speedErr2 = (speedErr-speedErrPrev); //DERIVATIVE???
  3.     speedErrPrev = speedErr;
  4.
  5.     result = (int32)(speedErr2 * kp);
  6.     piOut += result;
Same way here the difference of error is getting accumulated & will get you the proportional term.
[example - taking kp = 1,& ki = 0
           T0, speedError =0, speedErr2 = 0         , piout = 0
           T1, speedError =2, speedErr2 = [2-0] = 2 , piout = 2+0 = 2
           T2, speedError =3, speedErr2 = [3-2] = 1 , piout = 2+1 = 3
           T3, speedError =-4,speedErr2 = [-4-3]= -7, piout = 3+ -7 = -4
Now you can see the SpeedError = kp*piout in this example, this is what P have to do in the system. ]
Basically, integrate P, you will get I. Integrate D, you will get P.
Hope this makes sense.
Jobin GT
JobinT_31
Hello Manuel,
  3.     piOut += result;
  4.
  6.     piOut += result;
Jobin GT
Hello Jobi,
Thank you for your answer. Everything is clear now.
Manu.
