ScGr_289066
100 replies posted 50 replies posted 25 replies posted
Hi All,
During the install of PSOC Creator IDE (4.2.0.641), I got this:
Error: fmk.M0027: cyliveupdate.exe: Unable to start executable image: (C:\Program Files (x86)\Cypress\Cypress Update Manager\cyliveupdate.exe) (File=cyliveupdate.exe)
I have tried numerous times to repair the installation and remove it, deleting the install directories, yet after reinstalling, I have the same problem.  I at one time had PSOC creator installed and working (including update manager), but had to remove it to resolve other issues (with EZ-USB FX3).
Any help much appreciated.
Scott
RyanZhao
250 sign-ins First question asked 750 replies posted
Hi Scott,
The troubleshooting KBA is FYI:
Troubleshooting PSoC® Creator™ Issues - KBA217546
Ryan
Hi Ryan,
I read though KBA217546 and followed the instructions to remove the existing install and reinstall as administrator.  After that, there is still no update manager and it's directory is missing (e.g. c:\program files (x86)\cypress\update manager" is not present).  What do I have to do to completely remove PsoC 4.2 to do a "clean" install?
Scott
DaKo_463136
10 likes received 10 likes given 5 likes given
I have the same problem after upgrading to the latest PSoC programmer in order to get the Device Update 3.
Davud
RyanZhao
Which version of PSoC Programmer were you trying downloading and updating?
Ryan
Hi Ryan,
I am installing the current version of PoSC creator 4.2.
Like I originally posted, this program was at one time on this computer working, but I had to remove it to reinstall some CX3 tools.
Scott
RyanZhao
Seems this thread discussed same error. Does it make sense to the error you met?
Select debugging target window shows up empty
Ryan
Hi Ryan,
The thread you referenced is *not* the same issue I am having.  I am unable to install the Cypress Update Manager for PoSC creator 4.2.
I still cannot get it to install.
Scott
RyanZhao
Can the update manager work now?
Ryan
Hi Ryan,
No, update manager still doesn't work.
Scott
RyanZhao
Hi Scott,
The update tool in PSoC Creator can work on my laptop.
Could you double-check configurations of the network, e.g., firewall settings?
Ryan
FrCh_3649616
I had the same problem, simply uninstalling and reinstalling did not work.  I uninstalled Creator, then uninstalled Programmer (it was still there), uninstalled all peripheral packages, uninstalled all cypress drivers, deleted all cypress related directories in Program files,user directory and rebooted and reinstalled with "complete" option and it worked.
Still not working, no one has any ideas?!?
Scott
in addition to my previous post, maybe erase any mention of cypress in registry.
reinstall windows?
I can give cleaning the registry a try after removing everything again.
Reinstalling windows isn't an option -- not ready to spend a week or two reinstalling software!
Does not Cypress make a program to clean up it's registry mess?
Scott
