Hello Everybody:
1 there is something wrong when We try to download Hex file into mcu .
can you tell me what's wrong like that?
2 failed twice: windows10 X64 PC and windows 7 x64 notebook computer.
3 they both failed when using PSOC Programmer 3.28
4 J-flash V6.30d and V6.36d are also can not connected when we try to downlaod the same hex files .
thank u all
hi there。
the reason was the PSoC creator 4.2 need to be updated to latest status. step1 tools->Find new Components -> install checked components. step 2 Tools ->find new devices . After this 2 steps, Hex file can be download correctly.
thank you .
It seems that the hex files you have is not generated for CY8C4147AZQ-S475 device. If you are generating hex using PSoC creator please check if you have selected the right device for your project.
Yeshwanth
hi there。
thank you .
