Biohorizons
the code for the temperature sensor DS18B20 works fine using only the display. But when I add the BLE code, I can't get it to work, it disconnects before receiving the temperature value. I have tested the same BLE code with another max30102 sensor and it works perfectly.
Can you help me?
Thank you
Hi @Biohorizons ,
1) Please can you avoid delays added in your code.
2) Call CyBle_ProcessEvents in regular intervals. If any custom function is there which will consume more time for execution, please call CyBle_ProcessEvents inside it.
3) Please can you check the above code example shared for sending notifications.
Thanks & Regards
Pratiksha V
PratikshaV
100 solutions authored 5 likes given 250 sign-ins
Hi @Biohorizons ,
Please let us know are you using custom board or our Evaluation Board?.
Thanks & Regards
Pratiksha V
I'm using cy8c4248lqi-bl583
Thanks & Regards
Hi @Biohorizons
 Please can you check the Throughput example from PSoC4 BLE 100 projects in 100 days. You can refer GATT Notification - Data Outgoing example for sending notifications from one device to other device.
Thanks & Regards
Pratiksha V
Biohorizons
Hi @PratikshaV ,
I have another program for an i2c temperature sensor and it works fine. But with the onewire sensor I only get it to work with display .
Thanks & Regards
Hi @Biohorizons ,
Thanks & Regards
Pratiksha V
