Hi, I need support about additional include directories and relative path issue in Psoc 4.0. In my project, although I added my header file directory to related place(build setting-compiler-additional inc. dir.), I am taking the error that "No such a file or directory". I take screen shot to show the problem clearly. it is added picture. I find that to include file as: "#include ".../.../.../includingfilename/sourcefilename.h"". But, because of the characteristics of our project, i cannot use that way. I should include the file by the first way. But I could not. Could you give advise about the problem. What it can be reason of it.
Being an habbit, when I press Ctrl+s the quistion is sent witoud the picture:) The picture is that.
Can you just right click the "Source Files" folder in Creator, and add the the particular sourcefilename.h file there by using option of adding Existing Item.
of course I did It is not a solution for this. But thanks your answer
