Mar 05, 2019
09:49 AM
Mar 05, 2019
09:49 AM
I built the BOARD which contains the attached wiring diagram
If I connect only the CYBLE-022001-00 module to the programming connector
CN8, the component is programmed.
If I connect the whole circuit, the module is not programmed.
I ask if anyone can give me directions to find the problem.
Sergio
Labels
01:43 AM
Mar 26, 2019
01:43 AM
Hi Sergio,
Since the standalone module is programming without any issue and hence there should not be any problem related to Module side. Please check your external circuitry connections ( any soldering issue ) to resolve this problem.
You can also probe the SWD lines and analyze the waveform at different test points.
-Gyan
