PSoC™ 4
secic_4090646
I built the BOARD which contains the attached wiring diagram
If I connect only the CYBLE-022001-00 module to the programming connector
CN8, the component is programmed.
If I connect the whole circuit, the module is not programmed.
I ask if anyone can give me directions to find the problem.
Sergio
GyanC_36
250 replies posted 100 replies posted 50 replies posted
Hi Sergio,
   Since the standalone module is programming without any issue and hence there should not be any problem related to Module side. Please check your external circuitry connections (  any soldering issue ) to resolve this problem.
You can also probe the SWD lines and analyze the waveform at different test points.
-Gyan
GyanC_36
Hello Sergio,
     Your schematic picture is not clearly visible. Could you please attach pdf file ?
-Gyan
GyanC_36
Hi Sergio,
-Gyan
