@Vasanth @AnjanaM_61 @AnushaTR
I have two PSoC4 chips (CY8C4244LQI-443 and CY8C4245LQI-483) these can be independently programmed using the MiniProg4. If I connect both of them at the same time to a 10pin connector and try to select one of the chip in the Programmer and try to flash it the programming process fails. In this scenario, only one of the chip with higher memory is automatically detected by the Programmer (ie, the manual selection gets overwritten). Can anyone suggest a solution for this?
Hi @Ramesh_R
Can you please refer to this discussion and check if it helps? Also can you please specify the programmer you are using?
Thanks and Regards,
Leo
Hi @Ramesh_R
Thanks and Regards,
Leo
Hi @Ramesh_R ,
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
Leo
