user_4403586
Hello, I'm not sure which programmer can be used to program CYBLE-224116-01, can you advise one?
AnkitaS_51
CYBLE-224116-01  device can be programmed using MiniProg3, http://www.cypress.com/documentation/development-kitsboards/cy8ckit-002-psoc-miniprog3-program-and-d...
If you plan to design your own board, you can place the 10 pin JTAG connector there.
The CYBLE-224110-EVAL EZ-BLE PSoC Evaluation Board enables you to evaluate and develop applications with the CYBLE-224116-01 EZ-BLE PSoC XT/XR BT 4.2 Module whose detail is available at this link:
https://www.cypress.com/documentation/development-kitsboards/cyble-224116-eval-ez-ble-psoc-xtxr-eval...
Ankita
AnkitaS_51
Ankita
Hi Ankita,
Thanks for your help!
I had installed the programming software "PSoCProgrammerSetup_3.28.4_b4307.exe" but can't find CYBLE-224116-01 in the device family pull-down menu. Should I need to use another software "CyProgrammer_2.0.0.355.exe"?
You will find it here as shown in image below in PSoC Programmer 3.28.4
Ankita
user_4403586
I found it, thanks Ankita!
