vigic_2309616
Hi everybody,
I can not program Analog coprocessor SSOP82 with mini Prog 3.
I have updated all the drivers and software, but PSOC Creator4.1 does not support this device.SSOP28.jpg
Roy_Liu
5 comments on KBA First comment on KBA 10 questions asked
You can use search in this developer community(top right corner of the page) with key words of the message "The device was recognized but PSoC Creator does not support using it at this time", this was discussed in multiple threads for different PSoC family devices using Miniprog3.
The possible reasons/resolutions are 1) Circuit board hardware issue, 2) Upgrade PSoC Programmer to 3.27.1, 3) The MPN used in the Creator project is different with the MPN mounted on your board. etc...
Roy Liu
WeLi_2041066
Welcome! First question asked First reply posted
I am sure miniProg 3 (CY8CKIT-002) support this chip at Creator4.1.
I used bread board to test it.
Maybe you need check your hardware.
I think it must be something with the XRES Signal or Power Cycle. So something in Hardware Connection is wrong or collides with other Signal. Can you program the chip with Power Cycle instead of XRES?
