Nov 03, 2021
09:51 PM
Nov 03, 2021
09:51 PM
After successfully prototyping using the eval kit and EZ-serial firmware, we have manufactured our first set of PCBAs using CYBT-343026. Since we plan to manufacture on a mass scale, is there a way we can update the UART configuration for PUART using OTA, so that the MCU can communicate at a higher baud rate than the default?
Saes
Labels
PSoC 4 MCU
- cybt-343026
- ez-serial
08:47 AM
Nov 23, 2021
08:47 AM
Hello @SaEa_4705941
Sorry , you cant change the PUART baud rate setting over OTA.
You may change it after the FW download via command described in section 3.1.2 Changing the Serial Communication Parameters of EZ-Serial user guide: https://www.cypress.com/file/452971/download
Anjana
