PSoC™ 4
MiRe_4638356
New Contributor II
Hi
I have created a simple component to try to control flow based on data is a F0 (lots wrong with the example).
There are two things that I don't understand:
  1. fifoEmpty doesn't appear to be working as expected - the loop continues indefinitely.
  2. I am not getting shift data output
I have attached the example but include the images below as well.
Thank you!
Mike
MiRe_4638356
New Contributor II
Just realised that I have made a couple of really silly mistakes!
Mike
MiRe_4638356
New Contributor II
I meant to add that I am not seeing data being output, so I know that I have an issue somewhere but cannot see through it.
Thanks!
Mike
MiRe_4638356
New Contributor II
Mike
