We would like to estimate the current consumption of automotive PSoC4100S Plus.
We can find the Power estimator below.
But, we can not find the PSoC4100S Plus selection on "Select the device used in your design".
Is it possible to calculate with PSoC4100S? In that case, when using ECO, should I add the following data sheet value for ECO current consumption?
Finally, can I calculate the current consumption of the general-purpose PSoC4100S Plus even for the Automotive PSoC4100S Plus?
Yocchi
PSoC 4 MCU
I have discussed this internally and created an internal request for the support of this device to be added to the power estimator tool.
Best Regards
Ekta
Thanks for pointing this out.
I checked and I also could not find support for the PSoC 4100S Plus device in the latest update of the power estimator tool.
Please provide us some time to check internally regarding this.
Till then I would suggest you use the values given in the datasheet for the estimation of the power consumed by the device.
Best Regards
Ekta
Best Regards
Ekta
