where can I configure Cmod, if it is used by EZI2C (CSD[0].shield_pad)?
I am not sure if I can change EZI2C Interface to SCB[1], because on the Evalkit(4045) it looks for me that the EZI2C is only working with SCB[0]:
thank you
EDIT: If I do auto-assign, it assign Cmod to P4[3] = CSD[0].csh
what's the difference CSD[0].csh to CSD[0].shield_pad ?
EzI2C can be configured in SCB blocks 0 and 1. Just ensure that USB-I2C bridge is available to communicate with PC (Assuming you use tuner GUI)
in Eval kit, I assume you are using Kit-prog as USB-I2C bridge. This may be the reason you are using SCB0 block for EzI2C.
Regarding Cmod connections for various PSoC devices, refer to page 113 of http://www.cypress.com/file/46081/download
Shanmathi
