D_Sd_3235936
25 sign-ins 50 questions asked 25 replies posted
I would like to configure the pin to LOW whenever PWM is not active.
1. How can i do that?
2. How should i configure in PSOC the initial state? Initial Drive state LOW is disabled on PIN.
PWM and the PIN configuration: (issue in green circle)
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
Dear DimaSidi-san,
Thank you very much for your response.
I re-thought what was the problem with writing compare 0,
then realized that if the 0 is written during the cycle, which usually is,
it won't be applied till next PWM cycle.
Then I read the datasheet of PWM and wondered why we can not use "stop()"
according to the datasheet, stop also makes the signal to inactive state.
So I grabbed an Oscilloscope and gave a try.
Following pictures are
ch1 Yellow signal is PWM
ch2 Blue signal is TCPWM
ch3 magenta signal is enable(1) / disable(0) of PWM using each methods.
(1) using PWM_WriteCompare(0)
   As written above this is not a good choice for this purpose.
(2) using PWM_Stop()
  It works, but the transition from High to Low is rather slow.
So this may not be appropriate if you need immediate shut-off.
(3) using ControlReg with AND (Bob-san's method)
  Clearly the winner, sharp shut-off.
  But with a cost of a ControlReg and an AND gate, which should not be expensive though.
(1) Using PWM_WriteCompare(0) (and TCPWM_WriteCompare(0))
(2) Using PWM_Stop() (and TCPWM_Stop())
(3) Using ControlReg and AND
5-Feb-2019
Motoo Tanaka
jepaz
25 replies posted 10 replies posted 10 questions asked
I know this is not solving what you asked but you can also use the inverted output, you can configure that in the pwm tab. That would do the trick too
Bob_Marlowe
Level 10
Level 10
You may use an AND gate and a control register to force the output low.
Bob
Is there an example for the control register i can use?
Which PSoC kit do you use? CY8CKIT-0??
Bob
I am using the CYBLE-224110-00
Your device has got the required resources. See attached project.
Bob
MotooTanaka
Level 9
Level 9
I'm just curious, but doesn't set compare to 0 do the same thing without any additional circuit?
    PWM_WriteCompare(0) ;
moto
I remember reading in some post that this is not a good solution.
MotooTanaka
Level 9
Level 9
Dear DimaSidi-san,
5-Feb-2019
Motoo Tanaka
