PSoC™ 4 Forum Discussions
D_Sd_3235936
Level 4
Level 4
25 sign-ins 50 questions asked 25 replies posted
I have several questions regarding the PWM module:
1. What does the PWM_Stop() do to the line output?
2. What does PWM_Start() do if i yet to configure the PWM_WriteCompare(value)?
thnaks!
LinglingG_46
10 questions asked 5 questions asked 250 sign-ins
The Line output will be disabled also.
It will be floating.
You must set a initial compare value in the component, or you will not pass the project programming.
LinglingG_46
