Hi community.
I am using the PVref_P4 Programmable Voltage Reference on a prototype device within a CY8C4145AZI-PS423. This seems working very well. Within PSoC Creator it appears with a red background and is labeled as "Prototype", the datasheet referenced from PSoC Creator is labled as "PRELIMINARY". Meanwhile I found a datasheet with the same title "PSoC 4 Programmable Voltage Reference (PVref_P4)1.0" but inside labeled as "Document Number: 002-10611 Rev. *C", which is no longer "PRELIMINARY".
My questions: Can I use this component now for production? Will there be an update for this component within PSoc Creator, without "protoype" labeling?
Norbert Witt
Hi Norbert,
Thanks for the patience. I have received confirmation from our software team that the component can be used for production.
Vasanth R S
Hi Norbert,
We are confirming this with our software team internally. Give us some time to come back to you.
Vasanth
Hi Norbert,
Vasanth R S
Hi Vasanth.
Great!
Thanks a lot!
Norbert Witt
