Nov 19, 2015
05:49 AM
Nov 19, 2015
05:49 AM
I have a time of 500ms between reset and calling the main function. It is the function in start_c init_libc_array taking all this time? How to reduce this time?
I created a test project for moving only one output to test this time.
Thank you,
Eric
Labels
BLE
06:36 AM
Nov 19, 2015
06:36 AM
All the programming of the internal registers which include components and wiring is done after stabilization of the clocks and PLL. All registers get a value, so setup time is independent of the components used,
In cydwr-file, System tab there is a "Device Configuration Mode" setting which allows for using more flash but faster setup.
Bob
